Smeg STX1.1 dishwasher PC fault code?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg STX1.1 dishwasher PC fault code?
  • #29977
    whiskeyjack6058
    We have in our workshop the above Smeg dishwasher. It would seem that there is no way of setting the program because when you try it just comes up with PC on the display. Had a quick look throught the known error codes part of the ukwhitegoods forum and I cant find anything that relates to this. This is a very expencive dishwasher and the customer has told us to repair it at any cost nut it would be nice if I could get it right the first time.
    Anyone any ideas?
    Rob.
    #225400
    Re: Smeg STX1.1 dishwasher PC fault code?
    Its not an error code, i guess its PO with a duff display segment ? I assume the door lock hasnt rolled over into the door closed position? Have you tried swtiching on power and hitting the programme button 4 times before the display lights up, sometimes that re sets the programme. Only other thought is the usual dispenser coil problem which efects these machines in differing ways, slave on any old valve coil if only to eliminate it. Other than that, assuming the tray underneath is not full of water, it will probably bee an new programme card.
