Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg STX45
- This topic has 6 replies, 2 voices, and was last updated 17 years, 9 months ago by
sammy62.
August 2, 2008 at 4:02 pm #38484
sammy62
ParticipantHi
I have a F1 and C1 fault indicated on this smeg dishwasher
I advice welcome as its simply not working 😥
August 2, 2008 at 4:11 pm #259069Penguin45
ParticipantRe: Smeg STX45
C1 one indicates test programme selected. Try the following – With the door open, switch on, wait 3 seconds and press P button twice quickly.
Might clear it.
August 2, 2008 at 4:19 pm #259070sammy62
ParticipantHi thanks for your quick reply
Just tried it no joy
Its like this
I press power button
C1 is initially shown
then display changes to F1 with a double beepThanks for your help
would a factory reset help ??? 😕
Sam
August 2, 2008 at 11:03 pm #259071Penguin45
Ain’t no such thing as a factory re-set…… There is a re-set procedure applicable to the “5 LED” machines, but not appropriate to yours. Slightly worrying as well in that there is no reference to any “F1” code in any available tech info.
These machines are susceptible to corruption issues – there is an article HERE relating to the 5 LED machines. The basics apply to yours too, with the addition of the motor start/run capacitor occasionally wreaking havoc as well.
If you wish to keep the appliance, I would recommend getting help. They’re technically complicated beasts and can be singularly awkward to diagnose. Often, the only way to eleiminate a component is to substitute it. This is an expensive way for a non-trade person to fix it.
Power off if you are going to go in.
August 3, 2008 at 10:58 am #259072sammy62
😉 thanks Penquin,
It has had a history of not working when given a day off for some strange reason in the past with a double beep and no reaction to the programme buttonand failed this time on retrun from a two week hol
I was thinking of refurbishing the PCB as a last attempt.
http://www.qualityelectronicrepairs.co. … del_1.html
Sam
August 3, 2008 at 11:01 am #259073sammy62
:rolls:
PS I can get it to reun thru what seems to be a test cycle by 4 quick presses on start up and all seems well on that just won’t go to normal!
August 9, 2008 at 6:46 pm #259074sammy62
Hi P 😆
just left it swtiched off for a couple of days and it decided to work again!
Worth trying this if your not in a hurry
Thanks for your earlier help
Sam
