Hello to all,
My customer has the aforementioned Smeg oven, I believe it’s 10+ years old. When turning the main selector switch on, the RCD trips. I tested the ring element (which is less than a year old) with a multimeter and it’s in good shape & shows continuity. I went on a fault-finding mission to see what the culprit could be – I removed the ring element completely & it still tripped the RCD when turning the selector switch. The fan motor & light housing both tested positively.
Can anyone recommend what else the problem could be? Could a faulty selector switch or thermostat cause the RCD to trip?
Due to the customer wanting to prepare dinner for his daughter I was unable to spend any more time on it.
Many thanks in advance for your advice.
Jacob
