Smeg SUK62MFX5
  • #39939
    rocker
    Looking at fitting a new main oven stat..on connect site advising that org diamond h, is now changed to a ego version stat (part No 818730401)…is this a stright forward change over, or have the wiring configeration changed , if so do they supply a wiring diagram.
    any advice please John.
    #264213
    Lawrence
    Re: Smeg SUK62MFX5
    If its the main oven stat and not an energy regulator there is only two wires on it .
    Lawrence
    #264214
    rocker
    Re: Smeg SUK62MFX5
    cheers Lawerance, makes sense, was a bit conncerned as connect were advising to contact smeg for any tec info on this part.
    #264215
    Re: Smeg SUK62MFX5
    Have to be careful on some of these as the off position sometimes is 45 degrees out, you may also need to change the “square” it mounts on. If its a MFX5 version you should be alright though as its a later one than the one with the problems.
    #264216
    rocker
    Re: Smeg SUK62MFX5
    Eastlmark, not quite sure what you mean by change the square, dosent the stat fit directly into switch selector, I am not sure please let me know.
    Thanks John.
    #264217
    Lawrence
    Re: Smeg SUK62MFX5
    put the knob on ifi ts “out”slacken of the alan key screw in the centre & turn the knob outer round until it points to 12 oclock then retighten screw .
    Lawrence
    #264218
    rocker
    Re: Smeg SUK62MFX5
    Thanks Lawrence will do. John
    #264219
    Re: Smeg SUK62MFX5
    sorry to confuse, I was thinking it was the stat on its own rather than the one clipped into the comm switch. the “square” is the metal plate to which the seperate type stat mounts on to.
