Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SMEG SUK62MFX5 cooker with gas stove.
- This topic has 5 replies, 3 voices, and was last updated 17 years, 2 months ago by
FlyingBrick.
January 30, 2009 at 9:45 am #43012
FlyingBrick
ParticipantHi chaps
Have a customer with a Smeg SUK62MFX5 oven that has never been cleaned since new. Cannot even see through the glass window let alone the oven light.
Lower main fan oven is not heating up, timer set on manual.
Fan runs, light on beside the switch lights up, element stone cold.
Back off and element not shorting to earth and resistance across terminals ok for a fan element. TOC ok at room temp on the back to element.Is it the main electronic timer with the relay contacts burnt out on the pcb or the thermostat? Am I looking in the right general area.
Thermostat does click off and on when turned.On this model can you get the front cover off to get to the timer and thermostat quickly or does the whole back and sides need to come off to release the switch panel?
Any help gratefully received
Chris
January 30, 2009 at 10:15 am #275678electrofix
ModeratorRe: SMEG SUK62MFX5 cooker with gas stove.
silly idea ? you did disconnect element to read resistance
i prefer to test live no room for error
if element ok you need to know if live or neutral missing could be a chaffed wire that has blown to earth and now is o/c
hope this helps
January 30, 2009 at 1:19 pm #275679eastlmark
If the thermostat pilot light is coming on it will be a good sign that the thermostat is ok. It wont be the timer contacts as that would cut the fan as well. only thing left is the commutator, assuming the wiring is ok. Some SMeg dual fuels have a multi plug connecting the control panel to the terminal block and elements on the rear and these have been known to burn out. Stupid thing, but make sure you have checked to correct element as its all too easy to pull the wires off the grill element just above- done it myself!
January 30, 2009 at 1:45 pm #275680FlyingBrick
ParticipantRe: SMEG SUK62MFX5 cooker with gas stove.
Back again eastlmark & elctrofix.
Hands up doh, yes working on it last night round the back in the dark had taken off the wires from the grill element above as the vent directly below hides the fan element in her dark kitchen. ( one 60 watt bulb) Next time will bring in inspection lamp and not be so lazy.
3 coil element with the crazy bolts going through to the back so will have to take it apart and move everything yet again.That will teach me a lesson, covered in 5 years of black fat all from the cooker. Right, now to order the right element for cooker. Part No!
Thanks chaps
Chris
January 30, 2009 at 1:53 pm #275681eastlmark
806890386 is the part number.
January 30, 2009 at 2:11 pm #275682FlyingBrick
Cheers eastlmark
Have just put in the order for the 3 coil element.
Lets hope Royal Mail are quick on their toes in Norfolk.Chris
Back to surface mounted triacs on a blown Bosch dishwasher pcb.
Fun de-sodlering them. -
