Re: Smeg SUK62MFX5 thermostat
If someone prods me tomorrow whilst sitting in front of all the tech info I have between 9am and 5pm, I’ll look up the top oven thermostat for you. Smeg you need to get it absolutely right or it’s often completely wrong.
Often they will be different, can be different temperature ratings, offsets etc.
As to getting into it, hob stripped back usually, off, then you get to the control panel, strip that down… not an easy two minute job it has to be said.
