Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › SMEG SUK91MFA starts heating and then cools
- This topic has 7 replies, 2 voices, and was last updated 6 years, 3 months ago by
Ed Curtin.
December 19, 2019 at 8:56 pm #96916
Ed Curtin
ParticipantNo loss of power no power being tripped. Two fans are turning. Oven starts heating but 15 or so mins in it stops and looses heat
All lights are working timer mode isn’t set ie it’s not like unit is alarming and turning off, the thermo is clicking when turning on off heating manually
Fans are spinning on the elements at the back but the oven stops heating and cools down about 15 mins after food goes in
Thermostat Indicator light always on
Any ideas what I can try before calling in a professional
December 19, 2019 at 10:22 pm #465361electrofix
Moderatorbit confusing post
what do you mean by “All lights on time mode isn’t on”
when it stops do the fans continue but heat stops ?
December 20, 2019 at 2:41 am #465362Ed Curtin
ParticipantSorry it should of read power isn’t lost and thermo light is on main oven light is on when door opens and digital readout is on.
Unit does not trip anything and yes fans are on but heat stops
December 20, 2019 at 9:43 am #465363electrofix
Moderatorisn’t it funny had exactly the same problem on a smeg yesterday. my unit the fans run and the thermostat light is on but no heat. Im my customers and your unit there are 2 elements. This means there is 4 Kw of heat load which is too much power for the thermostat. Smegs answer is to fit a small power board to switch the load and these can go faulty.
https://shop.ukwhitegoods.co.uk/811650197-oven-electronic-control-board
in my case a small capacitor has blown so hopefully I can find one of an old board otherwise my customer will have no cooker for Christmas
hope you sort it in time
cant promise this is faulty but its high on the list
December 20, 2019 at 11:02 am #465364Ed Curtin
Participantelectrofix wrote:isn’t it funny had exactly the same problem on a smeg yesterday. my unit the fans run and the thermostat light is on but no heat. Im my customers and your unit there are 2 elements. This means there is 4 Kw of heat load which is too much power for the thermostat. Smegs answer is to fit a small power board to switch the load and these can go faulty.
Thanks for your reply Dave can I ask did you customers unit heat up at all? Mine is heating and then the heating cuts out
December 20, 2019 at 11:50 am #465365electrofix
Moderatorno mine did not but the component that had failed on the board was smoking slightly when I looked
I may be it starts ok then fails. if it was me I would test it to make sure
the way the system works is the thermostat tells the board to turn on the elements and the board closes relays to do that
if it was any kind of overheat stat I would expect a lot more to go offDave
December 20, 2019 at 11:58 am #465366Ed Curtin
Participantelectrofix wrote:no mine did not but the component that had failed on the board was smoking slightly when I looked
Thanks one final question you couldnt point me towards where I would find that board
December 20, 2019 at 12:00 pm #465367electrofix
Moderatormine was rear left hand side just above the terminal block
