Re: Smeg SUK91MFA5 Cooker
its a relay pcb to control the high power fan elements hence allowing the thermostat on the control panel to handle only a low current. part number is 811650197. The best way to check it is to connect a volt meter to the 2 wires between the relays and check you are getting 230v there when the thermostat is turned up, if so, and you cannot hear the relays click then it will be the problem. On some SUK91 this pcb only switches the fan elements while on others it switches all elements.
