Re: SMEG SUK91MFX – fan elements not heating
Is the fan itself turning? If it is and then no heat then most likey the element. Also visually inspection does not mean that it is ok it sometimes breaks from inside.
It is not easy on these cookers, so many screws to open,probably need two people.
Please switch the electrics off if inspecting.Otherwise better to call a pro if you are not confident.The resistance of the element is usually around 30Ohms(with the wires disconnected from it)
Rgards
