Smeg SUK91MFX fan oven element not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg SUK91MFX fan oven element not working
  • #74248
    phj1969
    i have a Smeg SUK91MFX oven which has 2 fan assisted elements, one of the elements does not come on.
    i have swapped them around and the same problem happens on the same side, so the elements are ok. Every thing else is working as normal.
    Any help appreciated
    #390576
    Re: Smeg SUK91MFX fan oven element not working
    have seen the cooker but cant remember specifics
    but
    assume its controlled by a pcb so are there separate relays for each element if so one could have gone
    hope it helps
    zarrax
    I know this thread is around 1 year old, but I have the same problem
    On the PCB I swapped around the 2 wires I traced for the right element (red and blue wires on rhs near relay on right – the relay being the small white sugar cube relay) with the two opposite corresponding wires. This made the other element work.
    I assume therefore that the relay is faulty.
    I am going to try to replace the relay, you can get them on eBay for around £4 or a new PCB is around £80
    #390578
    makes sense relays are normally the weak point
