Re: Smeg SUK91MFX Oven problem
The original 2200W element has now been replaced by a 1500W element (part number 806890442) and it is advised that both elements get changed at the same time even if only one is faulty to ensure an even heating performance.
So the correct power rating is now 1500W.
The issue with the oven cutting out is more likely to be caused by the thermal overload (safety stat) than the regulator stat you use to control the temperature. At this stage I’d advise getting an engineer out to examine the appliance because it’s a case of opening it up and checking components to diagnose this correctly.
