smeg suk91mfx oven stopped heating up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum smeg suk91mfx oven stopped heating up
  • #81769
    jonocole
    I have a smeg suk91mfx cooker.
    recently the oven has stopped heating up.
    there are a total of 4 different elements, bottom, top (grill), and 1 around each fan at the back. none of them are heating up when I turn the oven on but both fans are still running, and when you set the temperature, the orange light comes on and you hear the click of the thermostat.
    It seems pretty unlikely that all of the elements have blown so I’m guessing its a thermostat. I think the oven has 2 of them, one that is used to set the temperature and a safety cut off for if if gets too hot.
    any ideas what could be causing the problem? is there anything else it can be?
    any help would be much appriciated.
    jono
    #417654
    philfish
    Re: smeg suk91mfx oven stopped heating up
    If all have gone I would be looking towards the safety stat, but, in saying that there is a reason why that would go and that is the problem, you need to sort out that otherwise it will keep happening or be a danger to yourself. It’s a safety stat for a reason and obviously it gone for a reason.
    Phil
