SMEG SUK91MFX5 Oven and Grill not heating
Home Forums Public Support Forums Help And Support Cooker And Oven Forum SMEG SUK91MFX5 Oven and Grill not heating
  • #84177
    psrichards1068
    Hi, my oven and grill elements are not heating up. The fans and temperature neons are working fine. I have been reading the forums and deduct it is either the elements or the PCB. Where is the PCB located to check it and what is the best way to check the elements. Any info is much appreciated please.
    Regards
    Paul
    #424916
    Re: SMEG SUK91MFX5 Oven and Grill not heating
    board is this one
    http://shop.ukwhitegoods.co.uk/81165019 … board-9164
    it is unlikely 2 elements go down at the same time
    look at the board and look for bad solder joints first
    as far as i know this board is to allow 1 thermostat to control 2 oven elements. so it should no affect the grill
    take a good look at the oven selector switch for bad contacts
    psrichards1068
    Hi Dave,
    Thanks for your quick reply. Where is the PCB Control board located? I have looked at a couple of diagrams on the net, but none that I’ve found show it? I know from looking at one of the other posts on here relating to this oven there is a way to check (by moving a couple of the spade connectors) if the elements heat up. I just wanted to be sure before buying the replacement!
    Kind regards
    Paul
    #424918
    its at the back of the oven follow wires from fan elements
    but as above dont think it controls grill
    dave
    #424919
    psrichards1068
    I will check it at the weekend and update with results. Thanks for the pointers 🙂
    Paul
