SMEG SUK92MFX5 dual fuel range cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMEG SUK92MFX5 dual fuel range cooker
  • #55759
    jontymox
    Good morning all,
    Could someone let me know if I can r&r a suspect thermostat on the above unit as a non gas qualified engineer?
    The customer has reported that the small oven gets too hot, and the temperature will not reduce via the controls.
    I suspect the thermostat ass’y, although realise this is accessed from the rear.
    The unit has a gas hob, and I’m not sure about the above, as I don’t have much experience on these types of cookers.
    jontymox
    #325062
    chezza
    Re: SMEG SUK92MFX5 dual fuel range cooker
    You will struggle to get in to the thermostat on that unit without disturbing the gas , unless you have ultra skinny and very long arms 😆
    #325063
    jontymox
    Thanks chezza,
    Will probably refer to a gas or Smeg engineer, and concentrate on the other fault on this unit.
    Kind regards,
    jontymox
