Smeg Top Oven/Grill element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg Top Oven/Grill element
  • #17364
    snoody
    I need to replace the oven /grill element on a smeg A42 the element is slightly different to the original, the supplier says that a slight modification is required. Can anyone tell me what this modification is? Thanks
    #173958
    Dave_Conway
    Re: Smeg Top Oven/Grill element
    It depends which version of A42 you have (there’s a few), if you check the rating plate around the door there should be some letters and/or numbers after A42 🙂
    #173959
    snoody
    Hi Dave
    Iveactually fitted the part the part number is 806890527 from Smeg the difference being th original has a support towards the front tnew one has a differentsupport bar tat now extends the full width of the cavity and rests on the top of the gil pad rails
    Steve
    #173960
    Dave_Conway
    That’s why I asked for the full model number, to check the correct part number 😉
    If you go to http://www.smeg-service.co.uk you can ask online (live chat) what the modification is 🙂
