smeg top oven/grill not turning on.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum smeg top oven/grill not turning on.
  • #75764
    digitaldai
    smeg model: c62mfx5
    I have the problem that the top oven/grill no longer produces heat.
    The fan still comes on but orange light does not next to control dial. I checked the double element and get 28 ohm on one circuit and 50 ohm on the other which i take it means the element is ok?
    The control dial looks undamaged from the back with a torch, might take to front off for a closer look.
    anything else I can look at to fix this?
    any comments most greatly received.
    thanks
    #396059
    Re: smeg top oven/grill not turning on.
    assumed your model is cc62mfx5 not c62mfx5 as stated
    the seletor switch is the most likely problem
    see
    http://www.servevastdirect.co.uk/index. … ct_id=1324
    remove switch and look for burnt or broken switch contacts
