Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › SMEG UK STX2 Problems
- This topic has 5 replies, 3 voices, and was last updated 19 years, 9 months ago by
pbutterworth.
June 19, 2006 at 10:08 am #18562
pbutterworth
ParticipantHi,
I have a SMEG UK STX2 dishwasher thats just started failing.
It drains, fills, then just before it finished silling starts to hum, a sort of low buzz. This continues for a few minutes post filling then it just stops completely.
Any ideas?
Is there a reset sequence for this device I can try?
Cheers
Pauk
June 19, 2006 at 11:25 am #179450Dave_Conway
ParticipantRe: SMEG UK STX2 Problems
It sounds as if the circulation motor has failed or the start capacitor for it (the latter the more likely).
This post should help:
http://www.ukwhitegoods.co.uk/modules.p … =capacitor
Power off if checking please :zap: or you can find an engineer from the repairs@ link below if you’re unsure 🙂
June 19, 2006 at 12:13 pm #179451pbutterworth
Dave,
Thanks for the prompt response. Having a look underneath, there is one obvious capacitor next to what I assume is the circulation motor.
It’s some sort of dual capacitor that I dont remember from my electronics A Level!
It’s a 0.1uF dual, is this likely to be the beast?
A photo of the capacitor can be seen here:
http://www.dollymixtures.org/capacitor.jpgMy multimeter has died, but i’ll go to maplin & buy a new one if it’s likely to save a call out charge!
PaulJune 19, 2006 at 12:25 pm #179452Washman
You piccy looks more like the mains filter,not the motor capacitor . Motor capacitor should have 3 wires which go direct to motor and is probably attached to the motor and 10uf
Mike
June 19, 2006 at 12:44 pm #179453pbutterworth
Yeah i worked that out too eventually, the grey cells are a little rusty!
This looks more like it.
http://www.dollymixtures.org/capacitor2.jpg
It’s only got two wires though, any more clues?
Paul
June 19, 2006 at 12:48 pm #179454Dave_Conway
Yep, that’s the one which is why I gave the link to the previous post as it described the part and the link to our shop to purchase one if required 😉
Only two leads on this one 🙂
