Smeg UKC325XNF: Freezer alarm going off
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Smeg UKC325XNF: Freezer alarm going off
  • #81533
    hazelg
    Hello,
    I have a Smeg UKC325XNF frost-free fridge freezer, bought about 4-5years ago. Recently the alarm has been going off intermittently and the temperature reading for the freezer flashing to show that it has risen above -16 degrees. I turn the alarm off and after a while the red light has been going out and all returns to normal. I am ashamed to admit that this has been happening on and off for 3+ weeks but that for various reasons I had not got round to dealing with it. However yesterday things got much worse and now the alarm is going off every three hours or so and the warning light is on much of the time.
    The fridge seems fine: temperature shows 4 degrees, seems cool, butter is hard etc. The freezer does not have any frost build up and the contents don’t show any signs of having thawed (e.g. small amount of ice cream in the state it went in, not melted into a re-frozen puddle.) When I checked just now the compressor was hot and the metal panel at the back cool (although hot when I touched it yesterday). The water container at the back is full. I don’t know how much of this is useful information – please excuse my ignorance!
    We have tried the simple things recommended in the manual (reducing food in the freezer to improve air flow, dusting the metal panel at the back, turning the appliance off for 10 minutes and restarting) to no avail.
    I see you ask for a serial number; I have a number of 90126 0019 1 on paperwork which came with the appliance but I’m not sure if this is what you need.
    Any information or advice would be very gratefully received, including where to find a trusted repairer in my area (postcode N17 6DB) if necessary. Thank you very much.
    #416927
    Re: Smeg UKC325XNF: Freezer alarm going off
    Hi Hazel
    We cover your area for repairs.
    Bryan service@ffrservices.co.uk
    #416928
    hazelg
    r600a wrote:Hi Hazel
    Well ok, I may have to call someone out of course but I was hoping for some advice. Is there anything else I can try to see if it fixes the problem? Thank you
    #416929
    SAMURI
    Get someone to look after your food and turn the fridge freezer off with the doors open for 48 hours.
    It may not have defrosted itself properly and this will allow it to defrost.
    When you turn it back on it should be back to the normal temperature in 4 hours.
    If this does not work you will then need an engineers visit.
    Bob
    #416930
    hazelg
    Thank you! That is very helpful and appreciated. I will give it a go and let you know how I get on.
    #416931
    hazelg
    Wow, the defrost WORKED!! Thank you so much, Samuri, I seem to have a functioning freezer again! From the noises it had started to make before the defrost I suspect that ice had built up around the fan which had stopped the air being circulated properly.
    Thank you SO MUCH for saving me the cost of a call out!
