Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg UKST710 Drain pump
- This topic has 5 replies, 3 voices, and was last updated 19 years, 1 month ago by
pthawkes.
February 26, 2007 at 11:13 pm #25404
pthawkes
ParticipantHi All,
I wonder if someone can advise. Our Smeg UKST710 built in dishwasher recently stopped draining. I managed to get underneath the diswasher and found that the drain pump was stuck. I turned the pump fins and got the pump turning again. This solved the draining problem, but I think I must have damaged a seal on the pump as there is a vast amount of water collecting under the machine during a wash cycle. Also the draining cycle also make a lot more noise than previously(dodgy bearings I think).
The advice I need is: I am thinking of purchasing a new pump, are they reasonably easy to fit, or would the advice be that I pay the extra money and get a repair person to do it.
Many Thanks
PaulFebruary 27, 2007 at 12:19 am #205719kwatt
KeymasterIf you’ve gone that far then changing the pump is reasonably easy so long as you’re confident enough to do it. I’ll fire up a shop link in the morning for the pump once I dig up the info on it for you as I don’t have it to hand here at home.
February 27, 2007 at 12:23 am #205720Penguin45
ParticipantRe: Smeg UKST710 Drain pump
Good heavens – haven’t seen one of them in ages………. 😀 .
We can assume that the pump seal has gone, and water has got into the front bearing. Spinning it by the cooling fan has broken it free, so it will run, but water is leaking out.
If you contact spares@ukwhitegoods.co.uk and ask for an SM5101, they’ll supply the pump for you. Last price I recall was about £25 (it was a few years back), so not too terrible.
It’s a twist fit into the lower housing, so no reason you shouldn’t do this yourself, providing you unplug it first!
Penguin45.February 27, 2007 at 8:45 am #205721pthawkes
Many thanks for your prompt replies.
I am pretty confident then that I can do it myself. I just needed confirmation that it wasn’t a massive job.
Concerning the part I would appreciate a shop link to the part as I have looked around the web and the pump seems pretty scarce, and when I do find one its quite pricey.
Cheers for your advice once again.
PaulFebruary 27, 2007 at 9:34 am #205722kwatt
KeymasterFebruary 27, 2007 at 9:42 am #205723pthawkes
K,
Thanks very much, have just placed the order.
Paul
