smeg w/d click around end of program
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries smeg w/d click around end of program
  • #56786
    fasetester
    went to a smeg w/d model WDI12. when the machine is put on a wash it will fill up and wash then it does not move on to the next part of the wash.
    the programmer clicks around to the end of the wash. i tested it on rince and it seem to pump out ok. any one have this problum on this machine the lady said it only does it some times thanks fasetester.
    #328843
    fasetester
    Re: smeg w/d click around end of program
    well guys and ladies no one have any advise where all the smeg engineers . 🙂 fasetester
    #328844
    fasetester
    well ladies and gents no one have any pointers what to check. fasetester 🙁
    #328845
    fasetester
    this post has gone quite are you all on holidays 🙁 fasetester.
    #328846
    usually a no drain fault, or any fault if it clicks around to the spanner symbol, air bell, carbons, heater, blocked filter… take your pick really.
    #328847
    fasetester
    thanks mark for your reply. what does the spanner symbol mean can it be put into a test mode. fasetester
    #328848
    it means you need to call an engineer with a big spanner in his hand. Just a maintence symbol, no test prog AFAIK,
    #328849
    fasetester
    thanks mark for your reply. fasetester
