Smeg WashDryer
  • #68410
    Criscold
    Smeg WashDryer WD16BA
    Went to the above this morning and the machine stopped half way thru cycle and now refuses to start,
    The door locks and the timer/selector switch whirls followed by silence on all programs. Tested motor,pump,valves, interlock and anti flood switch in base and now suspect timer + module unless anyone can think of anything else that could cause this fault
    Colin
    #370978
    Re: Smeg WashDryer
    have you defo looked at those brushes? The initial whirl of the timer is a test sequence, if it finds anything out of order it will not start. Module could have dry joint on motor relay giving same fault symptom as brushes.
    #370979
    Criscold
    Re: Smeg WashDryer
    Spot On Estimark it was a dry joint on motor relay both customer and me now very happy
    Thanks for your help
    Colin
