SMEG WASHING DRYER NOT WORKING MODEL NUMBER WDI12
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMEG WASHING DRYER NOT WORKING MODEL NUMBER WDI12
  • #55946
    fasetester
    hello i was just enquiring about smeg washer dryer model number WDI12 type 22038. the problem seems to be its not working and doing nothing after it finished its last wash has anyone had any simular problems with this particular model or any knowledge of what might be the problem any information is greatly appreciated thanks, fasetester 8)
    #325701
    Re: SMEG WASHING DRYER NOT WORKING MODEL NUMBER WDI12
    doing nothing? no lights? then start at the on off swtich.
    if nothing obvious, check the brushes first can account for a dead machine on these.
    #325702
    fasetester
    thanks mark for your reply . is this a intergrated appliance the lady said it was flashing a light when i ask her which she said she could not rember. then she put it on a rinse program after finshing the main wash . and it was doing nothing i ask her was their water in the machine .
    she did not seem sure i dont think their was because she could open the door to get the model number . if their was a blockage in the pump would their be a fault code . if machine was complety dead could it be the door switch. are the just a interlock. thanks fasetester.
    #325703
    Pull out the main pcb…… Near the front of the machine had some with dry joints …….? Bit of a sod to get out but it will firer up after you remake dry joints…..
    Canufixit
    #325704
    fasetester
    thanks mark and canufixit for your help it seem like the on/off switch when u push down on it it works where the best place to order a switch. and how does the front switch pannel come off.
    does the timer knob and the other knobs just pull off thanks fasetester 🙂
    #325705
    its the obvious screws around the dispenser but there is also a hidden one screwed in form behind, it can be reached either with the top of, (if the machine is out) or by feel through the door seal, think you need it out to change the switch anyway. Knobs pull off but in this case can be left on. part number 816450249 £7.40 retail from servevast
    #325706
    fasetester
    thanks mark for your help does the on/off switch just clip out of the front panel . fasetester
    #325707
    yes from behind the inner front panel that is, its like the Hoptoint ones with a barb holding it in.
    #325708
    fasetester
    thanks mark for your help. fasetester
    #325709
    fasetester
    well guys i went and replaced the on/off switch put all togeather switched on machine starts to fill then in about 30sec nothing. 13amp fuse gone and 30amp in consumer blowen as well.
    machine sitting half full of water remove hose and empy water. still door wont open have to work at interlock to get the door open. disconnect wiring take note of where each wire is connected.
    check interlock from first terminal on right close lock with screwdriver should i not get a close citcuit across the switch to last terminal on the left.
    this is the wiring on interlock twin red from first terminal on the right this one does not seem right the next terminal over to the left which is the N on the switch to the heater is a twin brown and the last one on the left where the switch closes is a pink wire i dont know if anyone was at the machine before me.
    when i connected the hose up for the water it sprayed all over the place the lady said some one brother or husband said the hose was kinked so i put on a new hose . any thoughts or help welcome thanks fasetester.
    #325710
    You should have:
    2 reds to L (one of these goes to the microswitch on top of the interlock).
    1 pink to N.
    2 Browns to C (one of these goes to the other terminal of the microswitch).
    need to get your megger out!
    see here for wiring diagram.
    #325711
    fasetester
    thanks mark for your reply. when you check the interlock on resistance scale on meter should you not get a closed circuit between the first terminal on the right and the common. when you close the interlock with a screwdriver and between common and N fasetester.
