Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › SMEG washing machine WMI16AAA error code 13
- This topic has 5 replies, 5 voices, and was last updated 16 years, 3 months ago by
lonp.
January 3, 2010 at 10:29 am #51331
lonp
ParticipantHi there,
when we were using our washing machine (SMEG WMI16AAA) this morning, it stopped with error code 13 shown on the digital screen. there was softener left and if I chose Softener and pressed the start button from the dial it showed the same error, but it worked ok when I chose Rinses and probably the others as well ( we only tried rinses and Softener).
I found what error 13 means and it says “Malfunctioning of door block PTC” and we have no idea what it really means.
Could anyone give us advise what we should do?
If we have to fix this, does anyone have an idea of the cost?
Thank you.Regards,
R.January 3, 2010 at 12:43 pm #307626Penguin45
ParticipantRe: SMEG washing machine WMI16AAA error code 13
The activation device in the door lock is faulty. You will need to replace the lock as an assembly – p/no 814490202. spares@ukwhitegoods.co.uk will get you one promptly.
Power off if you intend to sort this for yourself.
January 4, 2010 at 11:07 am #307627lonp
Thank you for your help, Penguin45 .
December 2, 2012 at 11:31 am #307628Smeguser
I had the same problem with my WDI12C6 washer drier and I changed the lock successfully – BUT the E13 message and a clicking sound at the end of the cycle persists.
Can anyone else help pleaseJanuary 12, 2013 at 4:49 pm #307629stevebunyan
Does any one have the service manule for this Smeg WDI12C6 SN:00422/1725/1
Got a customer reporting same problem E13 flashing up at the end of a wash or drying program and continues to spin slowly. Fills washes, spins and empties ok. P/N-E 157ohmes.
On test I could reproduce the fault.
Has any one come across this fault.
He said he has had the door lock changed about 6 mths ago which according to the customer cured it for a short while then returned.
There is no crease guard selected.
At a loss, any ideasJanuary 12, 2013 at 5:02 pm #307630iadom
ModeratorRe: SMEG washing machine WMI16AAA error code 13
I would suggest you ask this question in the correct place, this is a public forum. 😉
