Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › SMEG WD16ba
- This topic has 7 replies, 3 voices, and was last updated 18 years, 8 months ago by
wd16ba.
August 7, 2007 at 5:43 pm #29581
wd16ba
ParticipantOn certain cycles, the machine doesn;t load. It starts the cycle but no water filles. I can use cycle 6 on a cooler wash but this isn;t much good.
Can anyone help? Is it repairable?
Cheers
August 7, 2007 at 6:14 pm #223709msappliance
ParticipantRe: SMEG WD16ba
Hi there,
Make sure that the water taps to the machine have not been turned off.
Does this machine have a hot and cold fill pipes?.
If so its quite possible that a water valve is faulty.
Unplug the machine before investigating.August 7, 2007 at 6:36 pm #223710wd16ba
Thaks for the reply. I’ve had a look previously and there doesn;t seem to be a blockage. Its only running of hot water fill. The cycle that does work, works ok. It seems to happen on the longer cycles only.
August 7, 2007 at 7:51 pm #223711Penguin45
This machine is fitted with both hot and cold water inlet valves. Both must be connected for the machine to function correctly.
August 7, 2007 at 7:58 pm #223712wd16ba
it has always been run off just hot. and still works but only certain cycles work
August 7, 2007 at 8:09 pm #223713Penguin45
Hot water required for some hotter washes. Cold water required for cooler washes and all rinse and dry functions.
Unless the hot has been connected to the cold valve, of course…..
August 7, 2007 at 9:37 pm #223714wd16ba
I haven’t just connected this. It was working correctly for ages. It has since stopped working correctly. I don’t think it can be how its connected as that hasn;pt changed.
August 7, 2007 at 11:12 pm #223715Penguin45
Have you checked? You ask for info and it’s a two way thing. Short of paying for my professonal services, it’s up to you to do the checking and respond accordingly.
At a guess, you have the hot connected to the cold valve, and now one of the solenoids has failed (it’s a multi-way valve). This would cause (for instance) the machine to fill for wash on a 40c cotton wash, then stop when it got to rinses; or even the conditioner rinse.
If you have got the hot on the cold BTW, you are rinsing your laundry in water up to 65c in temperature – this will lead to colour runs on dark clothes and laundry coming out like cardboard.
Please actually check and let us know.
Penguin45. -
