Re: smeg wd16ba
have a read of this, its the module in the front bottom corner:
With a fault reported on these models of not drying correctly, or taking to long to dry, may mean we need to change the main control PCB, this is the one in the bottom of the appliance.
Smeg have produced appliances in production that have a problem with the drying cycle, this is due to a fault on the PCB.
With appliances produced from April 06 to Sept 06 the appliances were fitted with a faulty PCB with a number on the card, if the number on the PCB matches this number reference (VSD010_C63) then the PCB must be changed. Depending on the model (please note washer dryers only) the part number from the manual of esploweb will be the correct one, as Italy have assured us that all stock of the faulty PCB have been removed from the spares lines.
part number is 696290789
