SMEG WDI 12 Bearing Replacement
Home Forums Public Support Forums Spare Parts Help SMEG WDI 12 Bearing Replacement
  • #42184
    cobraman
    I have a SMEG WDI 12 washer/dryer and is needing replacment drum bearings. TYP 22038 – NUMBER 0463422 383 It is coincidently the same as my old Bauknecht machine so i rescued the main bits off that apart from the ‘spider’ 🙁
    Is it possible to replace these bearings myself as I cannot find a kit on the website or if not, is there a complete spider available which would make life easier for me but a little more expensive.
    I am an mechanical engineer and i can see the pulley side bearing is an off the shelf type available at minimal costs. It would be nice to purchase from this website a complete kit, 2 bearings and seal with some basic instruction too. 😉
    Kind regards in advance
    Cobraman
    #272650
    Re: SMEG WDI 12 Bearing Replacement
    Bearing kit complete to suit your machine is SM0501 – spares@ukwhitegoods.co.uk will be able to supply you promptly.
    Cross piece has to come off for full access, so blower motor, drive motor and pulley all have to go before loosing off the retaining bolts.
    Make sure everything is spotless before re-assembly…..
    cobraman
    Thanks Penguin 45
    Got bearing kit and fitted this PM, about 4 hours. All sweet as a nut now, thanks for the info. Biggest part of job was cleaning everything up of all the ‘crud’ and limescale.
    Thanks again 😀
    Peter
