smeg wdi 16ba
  • #36408
    simonb
    fault e14 checked cutout on dryer on righthand side and is closed circuit ok
    theres a thermister over to left hand side located inside rubber manifold to dryer inlet, check for circuit and seems ok, not too sure about in range ohms?
    normally doesent e14 mean thermistor fault?
    can they go out of range and not just open?
    does just changing it rectify the problem in all cases?
    apart from that, machine works fine, fills spins,drains etc.
    thanks
    simon
    #250888
    Re: smeg wdi 16ba
    We always stick a new ntc in the rubber belloes at the front of the machine for a F14 fault, although have a tug at the wiring to it as they can break at the plug. its a common problem on these.
    #250889
    simonb
    Re: smeg wdi 16ba
    Great ill try one, iv tryed to find part number with no joy as yet but will try search on google tomorow.
    thanks simob
    #250890
    Re: smeg wdi 16ba
    817870012
    Lawrence
    Re: smeg wdi 16ba
    look underneath tub for another NTC may have a broken wire on block
    Lawrence
    #250892
    simonb
    Re: smeg wdi 16ba
    Thanks for part number chris!
    thanks gang
