Smeg WDI12 oddball problem
  • #29049
    don
    Help please ❗
    Customer reports fault with WDI12 s/n 0490781443 saying “grey sludge at rear of drum and on clothes”. Engineer calls and discovers that if you look at the rear of the drum through the porthole you can see the spider, collecting around this is all the sludge previously mentioned.
    Question is should there be a cover of some sort over this?
    Don
    #221302
    Re: Smeg WDI12 oddball problem
    The hole is the hot air inlet for the dryer. She’s probably had a nice bouncy load loosen up all the crud, so a couple of service washes should do the trick.
    chalky
    so thats what it is!!!!
    #221304
    It’s really quite a clever bit of kit when you start working on them.
    chalky
    Smeg ‘n’ clever in the same sentence? 😕
    #221306
    don
    Thanks P45 I`ll pass the info onto our guy. There you go chalky now we both know 😉
    Don
