been here today for not drying got it out half way as major fitting issues going back next week when better accessible.I was hoping for an o/load popped or something but when set on dry the fan kicks in but no heat theo/load stat has live to all 4 connectors and the heater has live to both sides so i am a neutral missing is there a common break in wire on these or is it fed from the board?
any advice appreciated
assuming there is no wiring breakages, then have to suspect the pcb down the bottom, poss dry joint I guess. Some of these had incorrect pcb’s fitted from new but I guess it has worked up to now so that shouldnt be an issue.
Any error code showing?
front panel comes off on that one. IIRC only need to access the 2 screws on the side of the facia which means it only needs to be pulled out slightly. Can acces the module that way.
cheers mark do you do much work on smeg as i have a part enquiry in trade spares if you can help on that one if not i am gonna ring smeg in the morning as electrue have no record of the model.
