looking at fitting a new door gasket to this built in washing machine,I have never worked on a smeg washer before, are these stright forward to do or any advice if not. please John
drawer out ,facia off ,then front panel off(look for three 7mm self tappers along the bottom edge )
then remove front weight on its frame ,then you you can get to the clamp band
then reverse order
