smeg wm63141bk Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › smeg wm63141bk This topic has 5 replies, 4 voices, and was last updated 12 years, 10 months ago by superfix. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts June 8, 2013 at 6:44 pm #75771 superfixParticipant Just had a mate on with an E4 fault on this machine, also said water coming out of the soap drawer. I thought E4 was a heater or NTC fault on Smeg stuff… Any ideas. Cheers June 9, 2013 at 8:23 am #396079 AllsortsParticipant Re: smeg wm63141bk Water coming out of the soap drawer could be simply that the tube has come off the pressure switch or the pressure switch is not operating June 9, 2013 at 8:56 am #396080 superfixParticipant Re: smeg wm63141bk Thanks for that, but apparently it’s also trying to ramp into spin and m/c is jumping around…. Guessing its probably a motor or pcb fault. June 14, 2013 at 7:12 am #396081 jason1970Participant Re: smeg wm63141bk Problem with the tacho on the motor? The ‘jumping around’ could then have pulled off the pressure tube? June 14, 2013 at 11:02 pm #396082 eastlmarkModerator Re: smeg wm63141bk superfix wrote:Just had a mate on with an E4 fault on this machine, also said water coming out of the soap drawer. I thought E4 was a heater or NTC fault on Smeg stuff… Any ideas. Cheers this is a Gorenje made model, F or E4 is a tacho fault. June 15, 2013 at 7:14 pm #396083 superfixParticipant Re: smeg wm63141bk Thanks lads all sorted Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
