Smeg WMI14C7-2 loud grinding noise on full spin
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg WMI14C7-2 loud grinding noise on full spin
  • #100394
    Thomocrew
    Hi, I was after some help in identifying the problem with my Smeg WMI14C7-2 making a loud grinding like noise when on full spin. After trying to search for this problem I have checked the drum for anything stuck inside the holes, there’s nothing caught between the drum and seal. I’ve come to the conclusion it is bearings? if that is the case would anyone know what ones to replace and how many of each I would need? Any other input is appreciated.
    #480432
    you will need both bearings plus the water seal and lubricant for the seal
    you might need the tub half gasket but a lot of the time these go back and seal but you never know
    you will have to check the drum shaft for wear and corrosion first
    site shop seems to have parts
    i think water seal may be this one but you need to check
    https://shop.ukwhitegoods.co.uk/754132252-smeg-washing-machine-bearing-seal
    the 2 bearing are fairly generic and shop should be able to point towards correct ones
    Thomocrew
    Thankyou Dave I completely overlooked the tub seal, I’ve put a message to the shop so hopefully they can recommend the correct bearings, what lubricant is used? and would you recommend official parts or compatible parts? are they just as good?
    #480434
    as long as the bearings are a good make and not a cheap chinese one it will be fine
    as for grease
    https://shop.ukwhitegoods.co.uk/universal-bearing-seal-sealant-grease
    Thomocrew
    Brilliant, I’ve ordered the real ones as directed by the shop along with the grease you suggested, thanks for your help and hopefully I can get it fixed
