Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › smegg dw
- This topic has 18 replies, 5 voices, and was last updated 16 years, 7 months ago by
adv.
August 19, 2009 at 2:53 pm #47930
adv
Participantdi c12c intigrated. switch on pic prog.fills an emptys at sme time ever cuple seconds. an prog light thats has been pict 😳 flashes an bleeps.any clues guys. its the newer style smegg ta no leaks in base
August 19, 2009 at 7:25 pm #295029adv
ParticipantRe: smegg dw
any one? 😆
August 19, 2009 at 8:56 pm #295030adv
wers the penquinn when u need him lol? :rolls:
August 19, 2009 at 10:43 pm #295031Penguin45
He was working ’til 7pm, had some dinner, had a quick run through UKW, took Twin1 to Air Cadets, tried to sort the misfire on the Wolseley, went and did some stuff on WolseleyForum.com, tried to sort out some part numbers on UKW, tried to follow the Spurs game on the radio, went and got Twin1 back from Air Cadets, tried to do a bit on UKW, then went to the pub. Nice relaxing evening, really. :rolls:
Right – corruption issues. Mains suppressors crack open and allow power through – sort of, but generate electrical noise. Dispenser solenoids become damp, have bad connections, soggy wiring and generate electrical noise. Start/run capacitor on motor can even do it. Once you work your way through that little lot, there is always the possibility that the (very expensive) pcb is simply borked.
What you’re describing does not sound like a “logical” fault, so the pcb is involved somewhere. All “standard” faults generate an error code.
:p45:
August 19, 2009 at 10:44 pm #295032eastlmark
ModeratorRe: smegg dw
as we always tell folks, first thing to look at is the dispenser, just connect up a solonoid valve coil if you dont have a dispenser to hand and at least eliminate that one which causes all sorts or odd faults. everything else you can test wihh a meter and if all seems ok and no leaks then it will be the PCB. Filling and emptying together for the first few minutes is normal.
August 19, 2009 at 10:46 pm #295033eastlmark
:waving:
August 19, 2009 at 10:47 pm #295034Penguin45
:waving:
E’oh…..
:p45:
August 20, 2009 at 7:51 am #295035adv
thanks . its filling an emptyin at same. time like pulseing ie fill drain fill drain . every second wreckin no water getin to machine cause getin pumpt out at same time weird 😳
August 20, 2009 at 9:44 am #295036eastlmark
certain that will be the dispenser
August 20, 2009 at 1:24 pm #295037adv
mmmm didnt thing a soapdispenser wud cause so meny problems on these dishwashers. why does it ?it wont be called to operate til water starts to heat up naw? :rolls:
August 20, 2009 at 5:55 pm #295038eastlmark
adv wrote:mmmm didnt thing a soapdispenser wud cause so meny problems on these dishwashers. why does it ?it wont be called to operate til water starts to heat up naw? :rolls:
dont ask, just try it!
August 21, 2009 at 9:40 am #295039adv
ok 😆
August 21, 2009 at 9:49 am #295040adv
the dispeners out of stock from connect wer else can i get it ta?
August 21, 2009 at 6:42 pm #295041Penguin45
Hook an inlet valve on it for testing purposes – then find the dispenser…….
August 23, 2009 at 7:32 pm #295042keithwilliams
no don’t buy a dispenser. just fit a coil. i’ve done it on my own machine and quite a few others. i agree that the fill empty bit sounds normal but i have had similar symptoms caused by a blockage in the side panel. similar to what happens when a bosch sump hose gets clogged. mind you it did give an overfill error message.
