My oven when you turn the temperature selection button immediately throws up an error errr8 and alarms, it is a SPF 125 oven with serial no. 31031
tried to book a repair and was told the part is a £9 resistor block which will be £100 all in fitted, but they can’t do it for 3 weeks which is obviously a long wait, can anyone shed light on the actual part I need so I can get my local man to do it ?
thanks
Sorry, you’re right it is SFP 125 ☹️
does this resistor fit the tangential cooling fan motor as I believe this is where err8 points to ?
doesnt look difficult to get to
thanks for your reply
It worked thanks for your help and reply’s, took about 20 minutes to do, celebrated with a pyro cycle which worked fine, happy days, £9 fix, that doesn’t happen to me that often !
