Re: Smeg(Whirlpool) FA720X (S25STRP) Freezer Temperature Pro
240 ohms is a very high resistance, are you sure it wasn’t 24 ohms?
You guessed correctly. The periodic spikes are consistent with the defrost cycle, although I thought they should be further apart i.e. 16 hours or thereabouts, but I guess it differs between manufacturers. it looks too consistent a pattern to be a fault.
IIRC there are two heaters on that type of fridge freezer. The first one is the defrost heater and the second is the drain heater. Have you tested both of them?
My money would be on a faulty temperature sender that’s linked to the overheat alarm.
