SMS69L12GB/28 FD 9101 01110 E15 water in base
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMS69L12GB/28 FD 9101 01110 E15 water in base
  • #77740
    Rograbbit
    Been to this today showing E15 at start of programme. Took both side panels off,couldn’t see any water. Don’t be fooled by these the water in base wasn’t visible, they must have a deeper well. When I tilted the machine some water ran out. This appliance is occasionally tripping the electric also.
    There are several posts on this, but I have referred customer to Bosch as only 2 years old, but have asked customer to let me know to see if can advise of the repair carried out. Let’s hope. Will let you know if I hear anything.
    P.S. Lid removal required on these to take side panels off. Very easy, two squeeze latches at front edge of lid, lift front edge, slide to rear.
    #403251
    Rograbbit
    Re: SMS69L12GB/28 FD 9101 01110 E15 water in base
    Customer had Bosch out to this appliance, but she didn’t give too much information. One or two seals changed, possibly lower door seal, and the engineer said the float switch was causing the tripping.
    If anyone has any recent service info on these especially relating to E15 would appreciate it. Thanks.
    #403252
    It’s always associated with a leak somewhere. As you mentioned the lower door seal also the salt container nut and in rare instances the matrix gasket leaks on the side of the tub.
    #403253
    Rograbbit
    Thank you Martin. Will delve deeper next one of these I get.
