SMV46KX00G/08 Bosch dishwasher
Home Forums Trade Technical & Spare Parts Forums SMV46KX00G/08 Bosch dishwasher
  • #103564
    HotDog
    This dishwasher has an e19 fault the code is heat exchanger fault I have tried a replacement motor/heater but no joy so I am thinking module before I proceed could there be an alternative option
    #493718
    kaibart
    That sounds like the heat exchanger on the left hand side outlet valve i think they call it
    #493719
    Hollytree_Technical
    E19 is usually an open circuit valve on the bottom of the heat exchanger tank – in this case the part number that you will likley need is 11033896
    Jem
    #493720
    kaibart
    Failing that it will be dispenser
    #493721
    HotDog
    Thanks think I have misunderstood the fault code as heater I call the the tank metering tank these parts keep changing there names fortunately I didn’t have to buy a motor/heater had a spare one
    #493722
    HotDog wrote:Thanks think I have misunderstood the fault code as heater I call the the tank metering tank these parts keep changing there names fortunately I didn’t have to buy a motor/heater had a spare one
    yes its a heat exchanger as it fill with cold water just before the end of the wash allowing some of the wash heat to warm it and save energy
