SMV53M00gb/21 not heating water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMV53M00gb/21 not heating water
  • #93582
    andcro
    I’m looking for some detailed help. I’ve got a Bosch integrated dishwasher that has recently stopped heating water. It doesn’t display an error or beep code.
    I immediately thought it would be the heater pump, but I put a meter across the two contacts where the larger red wires plug in and I get around 20 ohms – which seems about right.
    There are 2 other connectors – the 3 connector where the pin purple ribbon cable fits appears to have consistent resistance across each of the 3 wire options – so again I think it might be ok.
    The 3 pin Grey ribbon cable has only continuity across the middle and right connector at 14kohms- I briefly got 28kohms across one of the other combinations – but I’m not sure if this is right or not.
    I went back to the main control module – I checked voltages on the connectors for the red cables, the right was 120VAC – but only back to earth (which is strange) the left was 0 VAC.
    With the plug disconnected and the dishwasher running – it comes up with an E09 at the end of the cycle – this I think is as expected. With the plug connected – it just operates without error – but no heat.
    So – it could be a relay on the control module as I’m not getting voltage on one contact, or it could be a thermostat not telling the control module to switch on the heat?
    I’ve looked at the exploded parts diagram and can’t find an separate thermostat, so is it correct to assume it is built in to the heater pump assembly?
    The dishwasher is around 8 years old and I don’t mind replacing the heater pump or the control module but I’m not keen to replace both as it’s probably not a good investment.
    Thanks in advance for your help.
    Andy
    #454880
    Re: SMV53M00gb/21 not heating water
    Heater relay on the board primary suspect.
    #454881
    andcro
    Thanks Martin.
    I found the relay details – but stopped short of unsoldering it and testing it as it needs 240v to switch it (chickened out!) – sounds like I might have to bite the bullet and do it.
    Any suggestions on where to buy the relay if it is duff?
    Andy
    #454882
    RS or Farnell
    #454883
    andcro
    Well – I pulled the relay and tested it on the bench and it works fine, so this leads me to think it could be that it’s not getting the instruction to heat.
    Gutted really as found a supplier who were really helpful in matching a new relay.
    Is the thermostat built in to the heat pump on these? I can only find 2 other sensors on the diagrams – one is a turbidity sensor and the other I can’t tell – perhaps water level?
    #454884
    There are 2 sensors on the heater element inside the motor
    andcro
    Thanks Dave – so, sounds like replace the heat pump assembly then?
    #454886
    don’t jump to conclusions
    you need to measure the sensors (NTC’S) not sure of the value. think martin has tech access so if he reads this he may give you some resistance values
    of the ntc’s are ok it could be wiring or the main board at fault
    andcro
    I’ve continuity tested the wiring between the control module and the heat pump – all good. I realise there’s plenty on the control module to go wrong so I can’t test all that.
    It’s the NTC’s I’d like to locate – I’d come to the conclusion they must be in the heat pump assembly, but it’s only my process of elimination.
    If it was newer I’d take a punt – but it’s about 8 years old and I feel I need to be careful throwing parts at it – it could soon exceed the price of a new one.
    Appreciate you guys helping.
    #454888
    not sure if they are all the same but I split one a while ago for interest
    the picture is the heater
    NTC’s are arrowed
    andcro
    The connections look the same – did you find out what the smaller connectors on the right were for?
    I wonder if thats the NTC?
    #454890
    you beat me to it
    altered the picture
    andcro
    I checked the continuity on these – but I’m not certain of what it should be –
    #454892
    think centre pin is common so I would expect same reading between common and either of the other 2 pins
    when you got 28k its probably between outer pin which means each NTC is 14K
    andcro
    Just double checked – you are spot on, 14k from the left to middle – 14k from the middle to the right pin – 28k across the outer pins.
    Damm! Hoped that might have been the problem.
