smv63moogb/16 bosch dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries smv63moogb/16 bosch dishwasher
  • #77290
    robbo1973
    hi all cust has rang with this model number showing fault 17 which is the water level sensor has anyone got a part number as i cant see one listed?
    cheers chris
    #401654
    robbo1973
    Re: smv63moogb/16 bosch dishwasher
    anything on this as connect are saying they cant help either?
    #401655
    nomadPaul
    E:17 is normally the little flow rate meter on the water inlet failing as it’s to do with the pressure/flow rate of the incoming water. Could be too high a pressure. The part number is 00611317 direct from BSH – approx £12 . It’s the reed switch .
    #401656
    robbo1973
    #401657
    robbo1973
    cheer sfor info it turned out it was high water pressure but machine had never been moved in a year or two so strange?
