Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › SMV69T10GB/18 won’t start program unless pressure applied to door
- This topic has 10 replies, 2 voices, and was last updated 4 years, 5 months ago by
geminishootingtune.
October 13, 2021 at 3:41 pm #100130
geminishootingtune
ParticipantHello,
We have a SMV69T10GB/18 which won’t start programs unless pressure is applied to the door.
We’ve taken to placing a chair next to it and leaning the handle of a kettlebell onto the door.
Even then, sometimes we have to give the door a bit of sharp push for it to start and it will often stop during the program until we give it another shove. It’s not a specific issue with a single program either.
I think it’s a sensor issue, but would it just be a door sensor issue?
October 13, 2021 at 3:44 pm #479376electrofix
Moderatoris it fitted under a stone or wood work surface ?
October 13, 2021 at 3:55 pm #479377geminishootingtune
ParticipantIt’s a wooden surface.
October 13, 2021 at 4:15 pm #479378electrofix
Moderatoris the outer decor door catching anywhere ?
we get situations where the outer door contacts the work surface or surrounds just before the door is fully closed
October 13, 2021 at 5:15 pm #479379geminishootingtune
ParticipantHello Dave,
I don’t see it catching anywhere and it makes a positive “click” when closing it. How does the door close sensor work? The door itself has a plastic recess where the I assume the latch engages. Is it that or the latch itself that registers the closed door position (or both)? I can’t figure it out.
October 13, 2021 at 5:20 pm #479380electrofix
Moderatorits magnetic
magnet is in the frame, sensor is inside the dooryou can get a magnet and if you get it in the correct place it will activate it
October 13, 2021 at 5:24 pm #479381geminishootingtune
ParticipantAwesome! Thanks Dave!
October 13, 2021 at 8:24 pm #479382geminishootingtune
Participantelectrofix wrote:its magnetic
I applied a magnet around the sensor and it activates every time, although it’s over the area behind the sensor slot next to the control panel. Is that where it should be? Or should it be directly over the slot area? Is it a possibility that the magnet has moved (I can’t see how though).
October 13, 2021 at 10:40 pm #479383electrofix
Moderatorhave never had a magnet move yet
you can find out where the magner is by using a peice of steel
November 1, 2021 at 12:33 pm #479384geminishootingtune
Participantelectrofix wrote:have never had a magnet move yet
Hi Dave.
I replaced the sensor and unfortunately I still the same issue.
Is it possible that the door has become misaligned somehow?
November 1, 2021 at 12:37 pm #479385electrofix
Moderatorat the bottom of the door, on each hinge there is a plastic bearing
check its not damaged or missing
https://www.bosch-home.co.uk/store/00165296
