Snapped Oven Door Seals
  • #102559
    DWSERV
    I have a double oven with both door seals snapped at the joint and both are now obsolete with no alternatives. Has anyone had any luck with some of the new superglues that are claiming to bond anything together?
    #489435
    DWSERV
    Update…. this stuff is the dogs when it comes to gluing rubber. Had good success with the oven door seals. Should you decide to buy some, be extra careful and do not let the bottle tip over and wipe clean the nozzle tip every time you use it, as in my case the nozzle and cap completely welded itself together.
    https://www.toolstation.com/c-tec-superfast-plus-adhesive/p49296?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed
    #489436
    be interesting to see if it last as it states temp range 30 – 100 degrees
