I have inherited a 2007 Soba Eudora BabyNova 1000 washing machine in my boat. The drain pump is not running now and I need to test it. What resistance in ohms should I be looking for? It’s a 220 machine.
I’m also looking for a good source for parts for this unit.
The pump spins freely by hand. And I’ve done a visual inspection. I’m getting a resistance reading of .15 ohms.
I’m in contact with https://www.marinechandlery.com/ for parts but since this is my first search for parts I want to make sure I’m looking under every stone.
Following up on my post with a desperate cry for advice! I’ve replaced the pump on this machine and it’s still having the same problem. The pump makes a grinding sound but does not drain. All the lines are clear.
