soft start for vacuum cleaner
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries soft start for vacuum cleaner
  • #45981
    allan
    Hi something different 😆 Have an electrolux vac to repair its a z410a, the main suction motor has a soft start device soldered on to the switch assembly, its circular about the size of a penny, an ntc apparantly, badly burned so cant see any numbers on it. can someone guide me to replacing it with alternative from maplins??
    Thanks Allan
    Found this
    http://www.farnell.com/datasheets/307359.pdf
    #287874
    kladave
    Re: soft start for vacuum cleaner
    Is this the modern day 410 or the 410 that looks like 20 years old??
    If the later no spares were made available for that machine.
    Made in china
    #287875
    allan
    no modern day z410a, the part is an ntc apparantly, but where it is burned cant see numbers it should be a common part, its just knowing which values to go for from the chart that i have linked
