Solar plus model 48337 noisy
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Solar plus model 48337 noisy
  • #88236
    djlanky50
    When I turn my oven on then there is a noise that comes from the top of the oven. (It seems like it is between the top oven and the hobs) I can only assume its the cooling fan (if there is one)
    Is How easy is it for me to have a look myself and see if it loose or needs replacing please? It has been there for 2 months now and im keen to get it fixed.
    Thank You
    #437426
    Re: Solar plus model 48337 noisy
    chances are the fan is at the back.
    turn off the power and remove the back panel and see if you can access it
    Cooling fan is just about visible from behind a small panel at the back but the complete hob has to be removed to access it.
    Also note that there are two totally different cooling fans used on this machine so correct serial number is essential to identify, sadly they are both around the £100 mark. 🙁
    #437428
    djlanky50
    Thank you for your help. is it easy to get access to the back? Does anyone have a guide to remove the hob?
