Solenoid valve ‘letting by’ ????
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Solenoid valve ‘letting by’ ????
  • #68235
    Ist call of six this morning was to a Hotpoint washing machine. She also mentioned a fault on a built in Indesit dishwasher. Sadly she didn’t mention this on the phone so I didn’t have any time to have a proper look at it.
    Model DI450. 3rd light ( A02 ) flashing. Now according to our ‘in house’ fault code guides this is basically a heater fault.
    Heating system failure – the dishwasher does not heat the water
    •Check water heating element
    •Check thermostats or thermistors
    •Check wiring
    •Check pressure sensor
    •Check safety thermostat
    •Check heater relay on control board
    However in the actual DI450 manual it has this.
    Light 3..A02. Solenoid valve letting by.
    Inlet valve, connections, heater open circuit,
    heater Earth fault, inlet valve letting by.
    WTF does letting by mean????
    It is definitely not filling when off. 😕
    ELDAR59
    Re: Solenoid valve ‘letting by’ ????
    letting by is exactly that jim. allowing water into the machine without the valve being energised. 😕
    cheers
    #370279
    iadom wrote:It is definitely not filling when off. 😕
    You missed that bit Alf, Jim already sussed that one. 😀
    #370280
    ELDAR59
    sorry martin, i thought jim was asking what letting by meant! 😕 😕
    #370281
    ELDAR59
    if there’s irony in here somewhere, then i’m missing it!
    #370282
    I don’t know about irony but Turkey fat has something to do with it. :mrgreen:
    #370283
    ELDAR59
    the valve is letting turkey fat into the dishwasher???
    no wonder it’s not working then. 😆 😆 😆
    #370284
    :mrgreen:
    Apparently she said it was fine until she accidentally spilled Turkey fat over the controls. :eeek:
    All will be revealed, her husband will have to drag it out, he did the install and its a woeful job. :rolls:
    Watch this space. 😀
    ELDAR59
    yes jim, keep us abreast of the situation, it sounds like a real baster of a job.
    sounds like your best winging your way out of there mate. 😆 😆
    #370286
    :clown: :mrgreen:
