Solid Ring Built In Hob
  • #77259
    spanner51
    Hello
    A customer has got a cheapo solid ring hob from one of the sheds, and rang me to say one ring is getting too hot (almost to the point of glowing red) and making the top surface hot as well.
    I didn’t think this type of ring could overheat, even when on full.
    Is this even possible?
    Is the customer talking rubbish?
    Could it be a faulty ring?
    Any comments appreiciated
    Graham
    #401558
    repman
    Re: Solid Ring Built In Hob
    standard sealed plates have a thermal limiter fitted internaly
    but i have never had this complaint
    hope that helps?
    #401559
    Normally caused by saucepans that are either too large or of the catering type and the bottoms are not flat thus the plate doesnt sense the correct temp all over the surface thus causing the hot spots and can cause the blueing/tanning of the stainless steel hob top.
    Very common on the cheap cata crap.
    Bryan
    #401560
    spanner51
    Thanks for the replies
    I spoke to the customers carer, who is going the educate him on how to use the hob correctly, using the correct pan.
    Thanks again. Some usefull tips for the future.
    Graham
