Spare parts for AEG 65300 K Ceramic Hob
Home Forums Public Support Forums Spare Parts Help Spare parts for AEG 65300 K Ceramic Hob
  • #6735
    jamieboswell
    Hi All,
    My AEG 65300 K touch sensitive ceramic hob no longer switches on. I guess the PCB control circuit board has died. Does anyone know the part number for the PCB and how much a replacement part would cost?
    Model: AEG 65300 K
    Serial number: 14306484
    Product number: 949 485 635
    Year purchased: 2002
    Many thanks…
    #119309
    Re: Spare parts for AEG 65300 K Ceramic Hob
    Jamie,
    It’s over £200 !!!
    Are you sure it isn’t simply that you have used the wrong cleaner on the ceramic glass 😕
    Tip: Clean entire surface with a mild solution of washing- up liquid and water on a J cloth, then dry off completely with a paper kitchen towel. Then rub over with a clean/dry tea towel and try it again :tup:
    Fingers crossed 8)
    jamieboswell
    Thanks for the reply Martin. Being the curious type, I removed the glass top, blew some dust out of the touch sensitive pads and re-assembled. I managed to turn one of the cooking zones on for about 10 secs before it cut out again. I tried the on/off button again, but no response again.
    I guess £200+ for the part doesn’t make it worth replacing. Think I might change to gas!!
    I’ve used the same cleaner for 2+ years, but I will try your tip as a last ditch attempt.
    Thanks,
    Jamie
