Spin Cycle Leaves Clothes Wet
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Spin Cycle Leaves Clothes Wet
  • #84196
    macman35
    Bosch Maxx WFL 2450GB: when used on normal programmes (usually 40C Easy Care) the spin cycles leaves washing very wet. I have to run a separate spin cycle to get it acceptably dry.
    Machine has had a new pump, door seal and motor brushes in the last five years. I have checked the pump filter and drain hose; no visible obstructions.
    I’d guessing that the tub is not draining fast enough to allow the spin speed to reach maximum (I’m ruling out a motor or belt issue, since the spin speed seems OK when run as a separate cycle with no drain-out required?
    What else could this be? Pressure switch fault or pressure system blockage maybe? Pump beginning to fail? Imbalance limiter fault?
    I should add that the fault is intermittent at present, I’d say it happens 2 times out of 3-but the 3rd time the washing is spun sufficently.
    #424994
    Re: Spin Cycle Leaves Clothes Wet
    Easy care only spins to 800rpm.
    #424995
    macman35
    But I’ve used the machine many times on that programme without this issue. It’s not specific to any one programme.
    #424996
    Sock stuck in the sump hose? Pump knackered (lateral play in impellor)? Motor arcing?
