Apologies for not having the complete model number.
The drain hose on my Dishlex DX303 has split. It had been clipped to the inside of a kitchen cabinet using pipe clips that were too small – by the house’s previous owner. The clips have nipped and split the drain hose at 4 points. 3 of the splits are in an extension hose which I have a replacement for. The other split is in the drain hose from the dishwasher.
If I cut out the length of hose that has the split I will lose the rubber fitting at the end – so it then won’t fit into the extension hose.
It feels like it should be a really simple fix, but I just can’t get my head around something appropriate. 😳
1. Is it possible to repair the split in the hose?
2. If not, and the split has to be cut out of the hose, how do I then connect the end (now without the rubber fitting) to the extension hose?
3. Is there a third way – replacing the dishwasher’s drain hose?
Thanks for you help.
