Split fridge door seal gasket
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Split fridge door seal gasket
  • #101690
    Hard165
    Hi, I have a large split in my door seal on my fridge what issues can that cause? my fridge currently has stopped cooling but freezer works has the split door seal contributed to my issue??
    #485716
    It will allow warm air in, it will condense and you will get water and/or an ice build up as well as extended running times so, using more energy etc etc.
    It is not the reason for the problem you have. It may have contributed to it but a new seal will not cure it.
